Old 07-20-2013, 03:29 PM   #13 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
A lot of things change with the different tires, not only the weight but also rolling resistance, CdA (235 vs 195), circumference : the 235 is 2% bigger which means worse accelerations but also small benefit for mpg (outweighed by CdA and weight).
The worse performance is not only due to the weight.
To make the test consistent, they should have use always the same set of tires and put heavy balancers on the rims.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
