Old 07-20-2013, 11:12 PM   #31 (permalink)
manousos
Originally Posted by GreenHornet View Post
. . . the (OPRE) Opposed Piston Pulling Rod Engine, (PatOP) Single Crankshaft Opposed piston Engine, and (PatPOC) Single Crankshaft Opposed piston Engine of different design. These engines can be considered offspring of the Junkers Doxford engine. These are opposed piston engines that are direct injected with diesel. With some modification they can also be spark ignited gas guzzlers! These engines spend more time at BDC and increase piston dwell to increase engine efficiency among other improvements. They have far less parts as well as far less moving parts then a conventional diesel today. They are far lighter and much more compact in design. They can literally fit under the seat of your car how is that for packaging.
GH..
Thanks GreenHornet.
A "correction": the pistons of the OPRE and of the PatOP (in both designs the connecting rods are pulling rods in the meaning that the high pressure into the combustion chamber loads the connecting rods in tension) do spend more time (some 35%) in the "combustion TDC", but the pistons of the PatPOC design spend in the combustion TDC as much time as the conventional (push-rod) engines.
The full balance is another characteristic of these engines.
When the single cylinder OPRE drives a divided load, like two counter-rotating propellers, as in the Portable Flyer,
the basis of the engine is perfectly rid of inertia vibrations (forces, moments and torques) just like a Wankel rotary and a V12 conventional; the basis of the OPRE engine is also perfectly rid of combustion vibrations (not possible in the case of the Wankel rotary and of the conventional V12 wherein the engine basis has to provide a reaction torque each time an expansion takes place). See the video at the bottom of the Portable Flyer section of the pattakon.com web site and think what it means for a lightweight Portable Flyer.
A characteristic / advantage of the (single) crankshaft PatOP (and PatPOC) is that the main bearings of the crankshaft are rid of loads. Theoretically you can keep the crankshaft by your hands during operation.
"With some modification they can also be spark ignited gas guzzlers!"
Like the spark ignition OPRE with the tilting valves (animations at the tilting valve section of the pattakon.com web site).
Think about the rev limit and the power density.
Thanks
Manolis Pattakos
The Following User Says Thank You to manousos For This Useful Post:
GreenHornet (07-24-2013)
