If you want a smoother ride go big, The problem with tiny tires is they go deeper into holes.
With every car I have changed around tire size on I have found that you can go 1 inch taller and 1 size wider (10mm) with out any problem.
Trucks can usually go 2 or 3 inches taller with out issue.
Our 08 Hyundai has 1 inch over OEM spec taller tires on the back (but still on the factory rim). I already installed and tested them on the front. It looks funny with bigger tires on the front and plus I want the old smaller tires to wear out faster (that's why the new ones are on the back).
