Old 07-21-2013, 02:18 PM   #19 (permalink)
freebeard
You might take your question here:
About 84 results (0.10 seconds)
Originally Posted by California98Civic
Other size specs: Offset 35-45; bolt patter 4X100; lug size 12mmX1.5
-- VW uses 4x100 with 12mm bolts, but I'm not sure about the offset. Is the wheel centered on the hub or the lug bolts? I wonder if you held up the one against the other where the interference would be.
California98Civic (07-22-2013)
