Old 07-21-2013, 06:47 PM   #22 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
The thing is that the tires do NOT have the same diameter. They even say it : "speedometer error". There is 2% difference and that cannot be disregarded when you're measuring something at 0.1 mpg.
Originally Posted by GreenHornet View Post
If your goal is MPG then you want a light weight, tall, and narrow tire.
Why tall? Because of better rolling resistance? Taller tires are heavier and make worse aero. Big gearing should be done with the gearbox, not the tires.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
