Old 07-21-2013, 09:53 PM   #34 (permalink)
baldlobo
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
vago; where'd you get your fuel pressure from because everything i've read for every chrysler produced from 99 or earlier, on is suppost to be 49+/-5psi?
if your fuel pressure reg is actually getting 58+psi(you said 58psi over atmospheric so 72psi) you might want to replace/fix it; it might fix your problem
from a factory service manual
(4) If operating pressure is above 54.2 psi, electric
fuel pump is OK, but fuel pressure regulator is defective.
Replace fuel filter/fuel pressure regulator. Refer
to Fuel Filter/Fuel Pressure Regulator Removal/Installation
for more information.
