Old 07-23-2013, 09:12 AM   #1 (permalink)
justme1969
justme1969's Avatar
Alas Kia Got Wheel disc's on.
Undieing POS update.
The wheel disk/pan separators? work great for $27. and 1.5 hrs labor.
American Metalcraft - 18915 15" Round Pizza Pan Separator
I mounted with 4 screws drilled and tapped through inner wheel ring.
No squeeks and car seems much quieter now.
preliminary day run showed some possible coast down gains "negligible"
But I have to believe the absence of wind generated noise implied better results than what I seen.
Car seems more subject to wind shear side load from passing trucks though.
I cannot prove this because one of my rear tires wore out and I took larger size from broken honda for temps.
Investigating new set even larger than last 821 rev per miles v/s 835 from the current front 195 75 14.
It appears the POS was undergeared alot since it seems to enjoy the larger tires with out lugging down the engine on steep hill climbs, we shall see soon!
If ive exceeded the capacity of my clutch or Torque, I can just put the larger tires on back anyway so worth a try.
I will post Piks also if your going to do this mod be warned the honda 14" steelies with oval holes have a smaller inner ring so ensure all wheels are the same before running holes int covers.
Lesson learned because that temporary rear tire came with Honda round holes not squared Kia holes.
No biggie like I said the rear tires are worn out and round hole wheel goes back on the Honda anyhow.
One step closer to an avg 36mpg car I did hit a best ever 38 1/2 mpg trip Doing P&G behind a Semi on trip to Ga 2 weeks back. P&G is amazing but it sorta got my son sick after 3 hrs of it.
