Originally Posted by xntrx
Use the colder 4's. lean burn = less heat, so a hotter plug may misfire by not getting up to temp. If they made a 3, that might be worth trying, otherwise stay with the 4's.
I think you mean 4's are hotter. NGK lower number = hotter, higher number = colder.
