Old 07-25-2013, 05:25 AM   #7 (permalink)
nubbzcummins
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
Red face
Oem is hankook optimo H724 175/70/14 on 5.5"x14" steel wheel. Per tire rack this tire is 15lbs, 23.7" tall, and 4.5" tread width. Not buying diff wheel just tire change is what I am looking at doing. I put suspension in a few binds using 9" high ramps by driving up with one corner then driving up with opposite corners at same time and took many clearance measurements. I feel very strongly that I could not replicate this on the street especially under normal driving conditions.
With this being said I am looking at the michelin defender lineup: 185/70/14 listed as 19lbs, 24.3" tall, and 5.7" tread width. 195/70/14 listed as 21lbs, 24.8" tall and 7.4" tread width. 205/70/14 listed as 22lbs, 25.4" tall, 7.6" tread width.
Under conditions which I measured stated above and if wheel were turned the 185 should not rub, 195 very close and could go either way, and 205 would rub.
I can test using oem trip mpg and real time mpg functions and have a scan tool to view live data via obd2. Any suggestions on where to go from here?
