Old 07-25-2013, 08:49 AM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by UFO View Post
Yes, it is, and diesel fuel is more polluting than biodiesel too, so it may be worth it to figure out how to defeat the EGR/DPF on the new diesels in order to "convert" the vehicle to higher concentrations of biodiesel.
Water+meth injection helps to reduce the glazing from PCV oily vapors in the intake manifold, and from unburnt glycerin in the combustion chambers, while also decreasing NOx emissions. Promoting a more complete combustion process, and requiring a lower amount of Diesel fuel to generate the same power, the particulate matter amount also gets way lower, to nearly zero when the engine is properly tuned.
