Regarding the jacking points.
IIRC You have four corner weld under the body near the tires.
Weld a 4" x 4" square gusset at those points and make a small mark on the outside under body for reference.
That will also give the inspector a place to jack for your State Inspection when next you need one.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
