Old 07-29-2013, 10:24 PM   #36 (permalink)
ennored
The (left) body produced Cd 0.12,the (right) body Cd 0.21.
Guy I used to work with always said "If you were an air molecule..."
So, if you were an air molecule headed straight at the front of the three shapes, where would you like to go?
The left body is easy, any path around it is the same. The ones to the right are different. Superimposing a clock face, the 12, 3, 6, and 9 o'clock paths are the same simple paths from the left body. Anything but those paths is a longer path. And the war is lost...
