Old 07-31-2013, 03:04 PM   #46 (permalink)
tjts1
Nobody is forcing truckers to do anything.
YOU are forcing them to pass by breaking the law and blocking traffic. Take responsibility for your own actions.
V C Section 22400 Minimum Speed Law
(a) No person shall drive upon a highway at such a slow speed as to impede or block the normal and reasonable movement of traffic, unless the reduced speed is necessary for safe operation, because of a grade, or in compliance with law.
No person shall bring a vehicle to a complete stop upon a highway so as to impede or block the normal and reasonable movement of traffic unless the stop is necessary for safe operation or in compliance with law.
(b) Whenever the Department of Transportation determines on the basis of an engineering and traffic survey that slow speeds on any part of a state highway consistently impede the normal and reasonable movement of traffic, the department may determine and declare a minimum speed limit below which no person shall drive a vehicle, except when necessary for safe operation or in compliance with law, when appropriate signs giving notice thereof are erected along the part of the highway for which a minimum speed limit is established.
Subdivision (b) of this section shall apply only to vehicles subject to registration.
Amended Ch. 364, Stats. 1979. Effective January 1, 1980.
So the slowest guy on the road is, by definition, impeding traffic no matter how many other lanes are available? That's amusing.
I'm actually a part of the traffic too, believe it or not. I'm just not the most anxious part of it. It's not my job to make the speed demons not notice that I'm there, but I do go out of my way to minimize my impact on them. If that's not good enough for them then they can rot. If that upsets them too badly then I'll cheerfully play. It's been a few years since my last deliberate (it wasn't an accident), but I've got no problem making a bowl of riceboy soup.
When you get rear ended, you only have yourself to blame.
