Old 07-31-2013, 04:50 PM   #34 (permalink)
aerohead
estimate
Originally Posted by sendler View Post
Correct. And it is way too long and skinny to help us estimate the difference between the two Vetter tails pictured. The first 20% truncation of the fuselage basically chops off all of the boat tail already.
Ground effect: Any minimal ground effect that the two bikes have will be quite similar and can be tossed out as a common factor. We are only concerned with the comparative values. Nothing absolute. The 22* ice cream cone is closer to the actual bikes although it is too short. An 11* ice cream cone, or better yet, 4 feet tall hemi front rounded wedge at 11* on each side would give quite a good means of comparison as we chop off length in the front or the back.
Foil sim shows the x,y code for the given shapes but it can't be edited.
*If you can extend the lines of the Vetter fairing out to a point and then compare that to where they made the truncation you should be able to get a handle on the percentage of chop.
*The % drag difference per 10% of truncation difference won't really vary with fineness ratio.
*If you know the Cd of the profile your starting with,you should be able to predict the Cd at any given truncation.
*One thing about the straight taper.It has been shown to have twice the drag compared to the more complex teardrop taper.Eiffel measured this.DVL measured it.Junkers measured it.
*If you run a straight,conical taper as long as the 'Template' as Lay,K-Fachsenfeld,and Kamm did,you can get to very low drag.
*If you go from the hemi nose,directly into the angle,without the Mair contour transition,you'll lose the game right there.Sorry,but it's hard science.
*The thing about 'angles' is that they are measured at a tangent to the body,and will occur only as a constant after the curved Mair transition zone.
Without it,you'll have separation and a good chance that it will never re-attach.
*You can only cheat so much.
*You want to pull the body in as freebeard does with his redwood bender-board.I've been using 1" Schedule-40 PVC pipe as a 'french-curve' held over bulkhead station points which define major body vectors.The redwood or pipe will perform the calculus for you,plotting a smooth curve profile for fabrication.
*It's better to have a truncated body of proper contour than a full-tailed body of pseudo-streamline form.This was the entire premise of Kamm's research and university lectures.
*If you can go in the 11-degree territory it will return great dividends compared to the 22-degree which would only yield around Cd 0.23 even with a full tail.
I don't think you'll learn anything useful from the CFD.
mikeyjd (07-31-2013)
