Originally Posted by IsaacCarlson
It is a 2 door coupe. No sway bar on the front, yet.
Given the amount of work required to move the driveline, trying an anti-roll bar on the front, maybe trying a few different sizes if they're readily available, would be much easier if the only issue is handling balance.
What is the rear suspension design? H-beam? If so, that will have an anti-roll bar inside the cross bar of the 'H'. You might find a thinner/softer replacement for that.
It's a J-car isn't it? There's got to be a heap of models that use very similar chassis. Worth a wander around the junkyard?
