Originally Posted by Occasionally6
Connecting to only one injector works because if the injectors do open individually there is not much difference between the opening times of that injector and the injectors that open immediately before and after it.
I don't know what your Civic does but in many older cars all the injectors open at the same time once per engine revolution anyway.
Thanks "Occasionally6"
I'll link to an injector, but I will try to understand the code and later talves will use the four, door is no problem because I use the Arduino Mega
Sorry for my Inglês.
Thanks again
José Rodrigues
