Old 06-25-2008, 06:36 PM   #21 (permalink)
NeilBlanchard
Hello,
Originally Posted by lunarhighway View Post
yes sure, but that's the catch, total aero drag is frontal area (in square feet or meter) multiplied Cd
this is gives you a CdA
a tiny car with a 0.32 Cd might have less overall drag than a prius, just because the prius has more frontal area...
frontal area determins how much air will have to be pushed around the car, drag quoeficient how smooth this will go
Right, I understand that. My comment was towards what some posts seem to be saying: that just because a vehicle is taller, means that it must necessarily therefore have a higher drag coefficient.
The OP does list an item saying that "...lowering by 20 mm reduces Cd by 0.01" which implies that this is a linear affect. I can't see how this could be a constant? All else being equal, lowering a vehicle only reduces the frontal area of the tires only.
Both the Boxfish and the Aptera are relatively tall, and they have much lower Cd than almost any other vehicle; so height is only one possible factor in the Cd.
