I'm not sure what the tool is, but it sounds like your question is more about it than your actual Cd. You should trust it why?
The tool asks for weight but you didn't know yours?  I got my car weighed at a metal recycler right across the street. They weighed the front and rear axles separately. FWIW
weight 1985lb
front axle 840lb
42% front 58% rear
w/ driver 2200lb
What I want next is a light-plane pitot tube. It can mount where the AM radio antenna was.
This is the tool:
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Trust, and using a general tool, are two very different things.
I don't know the exact weight. Dry is 3447, I put in 3800, I believe.
