Old 08-02-2013, 12:06 AM   #15 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
So here is the new template (a bit more aggressive) on your car, if you go out to the end of the trunk it gets you out past the 30% hash, with 0% being the hash on top of the template/roof, 10% is above the c pillar, since you are at the 10% hash to begin with , going out to 35% would net you 37% better Cd, in theory. Your Cd would go from .35 to .22.
Your car is ideally suited for a kamm because flow off the back of the roof goes straight to heck. Its appears as though the designers were thinking when they radiused the area behind the c pillars to draw the air in to compensate for the seriously dropping air behind the rear glass. So this probably does not create a devastating vortex situation, but it certainly is a disorganized build in pressure from the c pillar back.
Any way, I guess my point is, if there was a car that could really benefit from a Kamm, it's yours.
Bigger Version of Pic to Oogle
The Following 2 Users Say Thank You to ChazInMT For This Useful Post:
aerohead (08-02-2013), Cd (08-02-2013)
