The fuel tank size or factory sensor have nothing to do with how the Scangauge calculates MPG. It only uses that information to calculate Distance to Empty.
The Scangauge and other MPG computers calculate MPG by reading the vehicles speed sensor to calculate distance. They also calculate fuel consumption over a specific time by using the constant stoichiometric mixture 14:7:1 and then using the vehicles mass airflow sensor (MAF) or manifold absolute pressure sensor (MAP) to determine how much air is used. Using the ideal 14:7:1 air/fuel ratio, we already know how much fuel is added based on how much air the MAP/MAF reports. That gives fuel consumption. The distance traveled over a finite amount of time divided by the fuel used over a finite amount of time gives us instantaneous MPG.
