Follow the slowest truck you come up behind. No slower. If the truck you are following passes an even slower truck. Then just stay behind that one. Stubbornly going too slow forces all the other slow moving vehicles that would normally just stay in line to use the left lane to get around you. Which makes everyone less safe. Cohabitate and cooperate on the roads. The slow line of trucks will be 2 mph under the limit. This is slow enough. Going any slower than this is just making a problem.
