your results are impressive, esp for a gasser.
the last fill-up gave me 58.8 mpg, calculated. the ultragauge gave me aroung that(but i always calculate anyway) but mph is not calculated right so i mostly use it for the instant mpg. besides airing up, front tires, this is from driving style.
i will be working on a rear belly pan in the next 2 weeks. i like to re-use so i tore down a gas water heater and will be using the outer sheet metal.
rear tires are next/at the same time. using Cooper CS4 195/65/15-91T, 80,000 wear rating on the front and getting very good results.
