Old 08-03-2013, 10:17 AM   #6 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Originally Posted by Jonathan6229 View Post
specificlly, wouldn't the DWB method be to pull in the clutch so you can coast the most distance? or do you coast up to a stoplight by just closing the throttle?
I've gone up 1 tooth in the front, and the bike acts like can go more, I did find "Gearing Commander" from this fourm, so when I figure out the best RPM range to cruise at, I can gear it maybe a touch higher.
Random question, how much does having the front fairing removed cost? (I was patching the plastics)
Removing the fairing impact depends on your average speed.
Airflow behind you is more important than in front of you.
A 500 is not gonna help you very much identifiying FE potential since it is so much powerful already.
