Thread
Some added tables for AS'Template' Part-C
08-03-2013, 04:24 PM
1
permalink
aerohead
I put these tables together from the original streamline body of revolution table to demonstrate how the drag will vary as it is brought down into ground proximity as a half-body,then what happens when wheels are added,and finally assigning a drag value to the wake itself.
NOTE: These values are only valid for the 12% thickness streamline body,although how the value percentage changes as a function of truncation percentage will be common to all bodies.
Here is a 2-D flow drag table I morphed from two in Hoerner's book.Remember,it's not 3-D,but you can see the effect of gaps and attempts to 'cheat' the air compared to 'ideal' teardrop forms.
Here is a table for 'J-form' wing/strut sections.Cd for the section is at left,and Cd of 'missing' portion is within yellow area
03:54 PM
.. Reason: add new tables
The Following 3 Users Say Thank You to aerohead For This Useful Post:
aardvarcus
(08-05-2013),
Cd
(08-17-2013),
freebeard
(08-06-2013)
aerohead
View Public Profile
Send a private message to aerohead
Find More Posts by aerohead
