Old 08-05-2013, 12:41 PM   #14 (permalink)
Viturro
Aerodynamics rules
Viturro's Avatar
Thanks! ,i should put the sides of the airfoil in the example.
Im don't agree with you in this ''The aileron is forcing high pressure air directly into the wake'' becouse, the angle on the wing and the angle of the kammback are the same, if the air separates from the kammback it will make some drag, like the upper part of the airfoil, then they sould be similar.
And the lift should be higher at certain speed when in the air starts to sepparate from the kammback, making drag, in the airfoil should make lift at the same time that reduces drag... maybe (?
also the upper part of the airfoil should make drag as the kammback or similar (more). so idk!
