''Viturro, the Flow Illustrator is just what it says it is, it "Illustrates" what you think the flow should look like. It is explained by its creator as this. It in no way can predict what the flow will look like because it is much too simple for that. You adjust the controls until the flow looks right to you.''
YES YES, OF COURSE, i know, but it's something. i put the velocity to 200 cos then you can see the ''air'' separating from the car, and no more cos i would need more space (large) of the drawn making the ilustrator slower (old pc) it's a balance.
''I think you are assuming the goal is to pack as much air in behind the vehicle as possible to reduce drag'' No, i know it has to flow, little by little, gently , that's why i dindn't made a 90ยบ wing, i made a similar to a kammback...but with air flowing under it... i think basically is that, that's why i dont think that there could be so much difference.
thank you, and thanks to you Frank Lee for the info, i didn't know that the lift was a vector!
