Old 08-06-2013, 12:53 AM   #4 (permalink)
WARCHILDSCRXHF
someotherdave...
1? so wait all crx are obd0? is that technical term or is there another name?
2? was there another technology or another label prior to obd0?...if so ill google it and research.
3? did you state if i do soldering wiring and programing than i can do the mpguino on the obd0.... or did you say that if i solder wire and program i can hook up obd2 and then scanguage.... i thought mpg guino was a fairly simply qucik easy hook up to a crx...
4? vacum gauge sound inacurate i saw a google image online of the item... looked finiky, and no good...true or no?...im guessing its a quick hook up.
5? is obd2 an easy hook up? or will ihave to go into engine bay and buy other items and open up the engine or something... i havent found any clean simply videos or google results for an answer on the time nmoney and procedure to determine if i want to execute.
