Old 08-06-2013, 03:17 AM   #6212 (permalink)
SEBART PL
SEBART PL's Avatar
Originally Posted by MPaulHolmes View Post
The overtemperature starts at 75 degC, and limits maximum motor amps in 10 steps all the way down to zero amps at 85 degC. You probably need to mount the controller on a heatsink if it's getting that hot.
The heatsink it is not a point, I drove for 75 miles with no problem, I did overload and system have not a chance to minimalize current, I have put wrong gear to see what happend and I know that I can't give car to my wife or other man. If only PWM could stop as quick as possible mosfets could get more chance to survive.
Other people experiance - Duncan, Adam who blown up mosfets proved that system is not quick enough when temperature is too high and they haven't got another chance to put bigger heatsink- in my opinion.
Paul, is it problem to put new temperature command or possible to overtemperature start quicker 65 C and limit motor amps i 2 steps half and 0at 75? I wish to have controll this parametrs.
The Following User Says Thank You to SEBART PL For This Useful Post:
MPaulHolmes (08-08-2013)
