Old 08-07-2013, 03:19 PM   #87 (permalink)
GreenHornet
GreenHornet's Avatar
So where is all of this 4 cylinder talk heading?
Well as you might of guessed it. I will be offering 3 versions of my TIGON diesel electric hybrid kitcar
Model #1 (TIGON GT2) = 2 cylinder .57 liter Yanmar engine based 5 speed electric hybrid. This will be for the person who wants MPG supremacy or 1 liter fuel economy performance!
Model #2 (TIGON GT3) = 3 cylinder engine undecided can utilize either 5 or 6 speed transmissions. This will be for the person who wants something in the middle of excellent economy and performance. Something between 1 liter and 2 liter fuel economy with much improved speed and acceleration over the GT2 model but not sub 5 second 0-60 acceleration like the GT4 model!
Model #3 (TIGON GT4) = 4 cylinder 1.9 liter VW TDI engine based 6 speed electric hybrid. This will be for the person who wants a solid 100mpg car that can also get you a fat speeding ticket in a blink of the eye!
The GT3 model I have considered using the VW 1.2 and 1.4 TDI engines as candidates. However getting the engines will not be easy tasks. Can it be done yes as I have a friend who imports them but they are not cheap! I am also considering using 3 cylinder industrial turbo diesels for this model with an increased electric motor and battery capacity to make up the power difference! From a parts and availability perspective as well as cost point of view this one is the most logical as there are 3 cylinder industrial diesels everywhere. I wanted to go with the Smart .8 liter engine but this would not be possible with the Triumph platform as you have to use the Smart Diesel transmission only! This is due to the way Smart has there ECU transmission settings integrated into the main ECU as well as the sensors on the transmission (Some would say that is Smart engineering but I say Dumb LOL). So unfortunately the only way to use the Smart engine is by going with a custom chassis platform in a rear engine design like the Smart or a front engine design utilizing both the engine and transmission. Which limits your gearing options to only that of the Smart car diesel!
The GT4 model utilizing the 1.9L engine was a pretty clear choice as they are abundant and proven. I also know that with my body kit design and hybrid engine design platform I can easily achieve 100mpg out of it. Even without my hybrid engine design I could get 100mpg out of these engines unmodified diesel only with my body kits for the Triumph Chassis.
So there you go guys the cat is out of the hat and now you all know my master plan LOL
Which is build Triumph Spit/GT6 kit cars based on diesel electric hybrid design of 2,3, and 4 cylinder variants. The cars will all use the same basic body kits with small styling updates! You will get a choice of 3 models the GT2,GT3, and GT4 with either a 5 speed T5 transmission or the larger T56 6 speed transmission.
The GT2 will have the 5 speed exclusively and GT4 will utilize the 6 speed exclusively. The GT3 will have the option of either going with the T5 or T56! The other option I am playing with at the moment is a rear differential swap for the GT4 models. While the GT4 1.9L TDI unmodified would be ok with the strongest Triumph GT6 3.27 differentials. The TDI engine is to easily modified to produce much more HP and torque with a simple chip tune. To me people would be way to tempted to do this and it would most likely result in them destroying the Triumph GT6 rear differential in record time!!!
So in order to prevent this highly likely scenario I am looking into common differential swaps that are well known to the Triumph Spitfire and GT6 crowd. Some of the likely candidates are the Datsun/Nissan/Subaru differentials such as R160/R180 other options are also the Jaguar E-type units that have the Dana 44 with inboard brakes. The Jag would be cool as the GT6 was dubbed as the poor mans E-type anyways so it would be cool to keep it with in that theme There is also the Ford 8.8" rear differentials that would give the ability for tons of gear options! So there are quite a bit of possibilities and options to consider here.
GH
