Old 08-08-2013, 09:24 AM   #6 (permalink)
haskie
Jetta - '08 Volkswagen Jetta SE PZEV
90 day: 26.54 mpg (US)
YJ - '92 Jeep Wrangler YJ Base
90 day: 16.02 mpg (US)
Originally Posted by UltArc View Post
Several threads on SC vs UG. I prefer the SG, even for the price. I drive speed limit on the highway, OR draft the fastest semi on the road - Ohio turnpike, they go from 65-75, occasionally up to 80.
Pump up the tires, and check out the ecomodder.com/forum/fuel-economy-mpg-modifications.php]65+ Vehicle modifications for better fuel economy - EcoModder.com if you want to keep your vehicle. Using just 10% of ecomodder.com/forum/EM-hypermiling-driving-tips-ecodriving.php]100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com will easily bump your MPG by >10%.
hmm I'll need to do more research I guess. Why do YOU prefer the SG over the UG? have you tried both?
Pump up the tires... I will research that one too. the 65+ was a good read, and so was the 100+, thanks
Originally Posted by mikeyjd View Post
type basjoos into the search engine ^
Good God. I just got done reading most of the "how to drop your cd..." thread... wow. He's definitely shown it can be done! maybe I should get a civic instead of this heavy vw...
