Old 08-08-2013, 03:20 PM   #26 (permalink)
oil pan 4
How much does the conveyer belt weigh?
Both sides together weigh less than 10 pounds and they are very ridged.
The heat treated 2024-T3 alloy didn't want to bend so I figured I would square the corners off. The air dam is so wide and comes down low enough it removes most of the need for tire spats, it also acts kind of like a forward side skirt since it follows the front of the body to just forward of the rear wheels.
