Originally Posted by niky
The current EPA may not be perfect, but it's the best "official" measure available at the moment.
Not, when you consider these two points: (1) all EPA tests are performend using 'neat' Indolene 91 octane gasoline, NOT the ethanol-diluted E10 stuff everybody is forced to use; and (2) some manufacturers stipulate milage tests be performed with daytime running lamps (DRL) and automatic headlamps and other "normal" electrical loads disconnected (which can only be done by pulling fuses!). So, how often do you pull fuses before you drive to work?
Also, up to now, EPA has NOT had a standard E85 fuel specified, so they relied upon numbers provided from manufacturers tests. They, now, however, have proposed an E85 standard fuel...but, it's not (yet) been approved.
