Old 08-10-2013, 01:08 AM   #4 (permalink)
star_deceiver
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Conveyor belting is a good idea as stock airdams are notoriously flimsy, as are the clips that hold them. I damaged mine within the first month on a small snowbank then proceeded to hit it several more times while doing a little winter offroading. Frozen slush blocks off other vehicles also took their toll on it. Soon after it was taken off and put into the trash.
The stock tire size will vary quite a bit depending on trim level and cab size but that size is fairly common.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
