Old 08-10-2013, 12:38 PM   #5 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Originally Posted by UltArc View Post
Oh, I didn't know I could add images to my garage that way. I thought the only way to put them in the garage was to upload them. How does one do it by Photobucket?
Actually it works the same way in your Garage as it does in your posts. You add images the same way. Upload your photo's to your Photobucket account. Get the link to the image. Head over to your Garage, click edit. Then in the General Description area, or any other large text box, add the [IMG] tags before the image URL. Follow the URL with the [/IMG] tag.
Your images will show up in the Garage. One tip, make sure to use small dimension photo's as it will not re size. The size can be unlimited since the image is hosted at a third party, and you can add as many images as you want.
I uploaded one as an example: Details: Lean and Mean - 1998 Honda Civic HX Fuel Economy - EcoModder.com
Another tip, you can use the same formatting in the Garage section as in posts. BBcode is the code formatting. For bold you use the [B] tag, for underline it's the [U] tag, and so on. It's just a matter of figuring out the tags.
1998 Honda Civic HX - My Project Thread
