Old 08-11-2013, 01:02 PM   #24 (permalink)
oil pan 4
I am building one now.
I have a 220v 3hp single phase 2 pole (3750rpm/noload) motor with 5/8'' keyed shaft and a standard 2.5gpm 3,000psi pressure washer pump that takes a 3/4'' shaft. Going to couple them together with an aluminum jawed urethane spider shaft coupler and a 3/4'' keyed shaft.
If I try to spin the pump up to full speed (3700 to 3400 rpm) at 3,000psi and try to get 2.5gpm out of it that's come out around 4hp.
So if standard 2.5gpm nozzles cause the motor to draw too much power then I will go to larger nozzles to drop the pressure and the power consumption.
