Old 08-13-2013, 03:10 AM   #98 (permalink)
serialk11r
Originally Posted by Old Tele man View Post
It's cast iron probably to keep the turbocharged block from "blowing-up" when the engine is forced (pun intended) to produce maximum horsepower. Aluminum blocks maybe much lighter but they're also much weaker too.
...here is a link to R&T magazine article: http://www.roadandtrack.com/go/news/...gine-announced
If they wanted to strengthen the block they could've used steel liners, cast iron liners, or composite reinforced liners. Aluminum block Subarus do just fine, MMC liner 2ZZ-GEs and K20s hold massive amounts of boost. It's cost, not strength. Cast iron block is cheap and strong, but worse.
The Following User Says Thank You to serialk11r For This Useful Post:
Allch Chcar (08-16-2013)
