Old 08-13-2013, 06:08 PM   #5 (permalink)
Awd180
wrx - '02 subaru impreza wrx wagon
90 day: 33.81 mpg (US)
Leg - '05 Subaru Legacy 2.5i
Don't. But a subaru can be pop started and yes it has to be towed on a flat bed. I have bump started threw the ignition in neutral. Some other heads up, the tmic stays cooler while moving engine on, which you want, if you believe in the wai take your Hot side heat sheild off (you'll get misfires from the fuel auto igniting). My intake manifold is cool to touch after a nice drive. Also, the amount of heat from the hot side w/o sheild will cause electrical components to fail from prolong heat. There's more, but a lot comes from doing research and $$$$$.
