kach22i : Would it be all right with you if we also post tuft tests here as well ?
Unless you really know what to look for, I'm guessing most of us can't see turbulence with smoke testing as easily as you can with tuft testing.
With tuft tests, you can literally see the pockets of air that are causing problems and the direction of the airflow.
