Old 08-15-2013, 05:47 PM   #27 (permalink)
oil pan 4
Ok the 3/4'' keyed shaft and spider couplers are in, they fit together perfectly.
The motor and pump should be in tomorrow.
I want to wire it up so that a low voltage momentary switch on the spray wand turns the electric motor on and off.
That way I don't have to worry about the motor flipping the circuit breaker when it goes to bypass or worry about the pump or motor over heating from being on but not spraying water.
