Inspect more mechanical issues before determining the wheel issue, the rim and tire combo is common on a lot of including civics, but some have 15 or 14. Check gear fluid, if there is no dipstick" drain it and fill with the recommended synthic. No cel?? if cel check for solution, also clean maf and iacv.
