so, swapped over to 4.56 from the 3.23
here are the two rear ends, 4.56 built into a 97 diff on the left-
also put in steel leaf springs with a higher load capacity. I did make the van heavier doing this, Id estimate each leaf was 3 times heavier than the fiberglass monoleaf. However, the fiberglass had to go, not so much the springs themselves as the hangars were close to failure
4.56 diff installed-
The immediate difference is no sluggishness in first, and I can pull overdrive on the highway now! very excited to see what new MPG numbers this might present for me.
I can also do hill starts, which was a hit or miss thing with the 3.23.
