Don't use a 3/8" socket on the crank pulley bolt. You need a 1/2" drive socket. And a good way to hold the crank from moving, like a screwdriver jammed in the flywheel teeth or some such.
Or use a really good air hammer/impact wrench on it. That puppy is on TIGHT!
-soD
