Great news on the axle/gear swap!!
Can't remember if tires were discussed. Truck-spec closed-shoulder highway rib tires would be my choice for another "major" change. Or, what is best suited to climate/terrain and truck use in a premium brand of tire if time/miles anticipated warrant it (MICHELIN, not BFG; Bridgestone, not Firestone. Etc). Tires are not the place to go cheap. They'll more than pay for themselves on a work truck. Same with shocks: Bilstein over Monroe, etc.
Has brake drag been looked over, front and rear axles? Same for steering slop, from column out through end links . . big truck manufacturers note this as a measurable FE problem.
The precise steering and "feel" of a tight front end, well-adjusted brakes/bearings and no-slop steering system coupled to premium tires/shocks is the feedback needed for low fuel burn tactics on a truck. The pieces needed to fit within a "smart use" strategy.
