Old 08-16-2013, 08:46 PM   #80 (permalink)
cRiPpLe_rOoStEr
Originally Posted by rmay635703 View Post
If I hit the "right" mix the car runs with less herky jerky and is much more smooth.
In higher-compression engines, ethanol can eventually enhance the mileage. My mom has a Brazilian-made Chevrolet Celta (basically a rebodied Opel Corsa B) with the 1.0L VHC engine, which compression ratio is 13:1, and it knocks like hell when the ethanol content in the Brazilian gasoline is lower than 25%. Back here ethanol blends in gasoline are mandatory, around 20-25% depending on the sugarcane harvest, the regulator stocks at National Petroleum Agency and other factors. It's the cheapest octane booster back here...
