Old 08-17-2013, 06:41 AM   #6 (permalink)
josemapiro
Originally Posted by t vago View Post
Those lines should really read:
Code:
#define vssBit (1 << PINC0)
#define lbuttonBit (1 << PINC3)
#define mbuttonBit (1 << PINC4)
#define rbuttonBit (1 << PINC5)
It sounds like you might have connected your buttons by mistake to the reset pin. Somebody who is more familiar with the Arduino Mega may be able to verify that.
If you set the pins as indicated, but for the mega pins gives error.
mpguino_alt3_ino:251: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:251: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:251: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino.ino: In function 'void __vector_10()':
mpguino_alt3_ino:398: error: 'PINK8' was not declared in this scope
mpguino_alt3_ino.ino: In function 'void mainloop()':
mpguino_alt3_ino:577: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:577: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino:584: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:608: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:608: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:608: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino:613: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:613: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:613: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino.ino: In function 'void editParm(byte)':
mpguino_alt3_ino:1368: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:1368: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino:1379: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:1407: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:1407: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:1407: error: 'PINK13' was not declared in this scope
mpguino_alt3_ino:1412: error: 'PINK11' was not declared in this scope
mpguino_alt3_ino:1412: error: 'PINK12' was not declared in this scope
mpguino_alt3_ino:1412: error: 'PINK13' was not declared in this scope
Here is a picture to help with the mega pins.
Thank you
José Rodrigues
