The thread is 5 years old. How did you find it?
I was going to post some thoughts about it ... but figured I'd do a site search first for a similar older thread before starting a new one.
And wa-la ... found one ... some of the things I would have posted were already covered ... this way if discussion does continue , it's all together in one place.
Speaking of which ... one thing I didn't see posted about yet ... the other aerodynamic benefit separate from body shell getting tightened up ... is that the heating of the air will reduce it's density , which will reduce the drag to push it out of the way ... even if this density change is a very small effect... still there, in addition to the other body shell.
I haven't read all five pages, but surface radiators and corrugated skins went in and out of fashion in the aircraft industry in the 1930s.
there are pros and cons ... some of the major cons are significantly reduced with a modern HEV & PHEV system that doesn't idle , uses less or no ICE at low speeds , etc.
How cooling is done:
A fan but no radiator, all in the wake.
Love that.
