Old 08-17-2013, 10:27 AM   #31 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
It's not a given that pressure higher than placard = increased center wear. Depends on the car, depends on the tire. It hasn't happened to me on 3 different cars, 3 different tires.
Adding another one to the count; I ran at least 10psi over the manufacturer recommended 32psi, up to and including max sidewall (51 psi), in the OEM tires on my Fit, and they wore evenly.
The Following User Says Thank You to wdb For This Useful Post:
101Volts (08-21-2013)
