Originally Posted by ttoyoda
Measure the value of his resistor. Get a resistor of the same value for a penny and try it yourself. I think it must be a pretty high value resistor to make a difference, because the input resistance of the ECU must be very high. Now if you are talking about injecting a voltage into the O2 sensor wire, that is something else.
Are you suggesting pulling up the signal with a voltage gain?
