Old 08-19-2013, 08:04 AM   #9 (permalink)
josemapiro
The error above was my mistake, define, # define vssBit (1 << PINK8); # define lbuttonBit (1 << PINK11); # define mbuttonBit (1 << PINK12); # define rbuttonBit (1 << pink13), but these pins is not are the correct, the correct are# define vssBit (1 << PINK0); # define lbuttonBit (1 << pink3); # define mbuttonBit (1 << PINK4); # define rbuttonBit (1 << PINK5), the K Pins are 0 to 7.
I've been a bit sleep.
But even with these changes, the problem remains. Will be a registration on the changes I made, what needs to be changed too?
Any registration that points to a different Pin.
Thank you
José Rodrigues
