Old 08-20-2013, 02:34 PM   #48 (permalink)
NH scrap
pizza runner - '94 toyota corolla dx
Originally Posted by ps2fixer View Post
Sounds like mine except you have the stick model.
Just to note, most of the driving is more or less ideal, not many stops and an hour drive each way to work. Under the hood there is a sticker that says what engine size the car came with factory. If I remember right, the DX only came in a 1.8L. I got about the same miles too at 260k .
Anyway, good luck with your corolla .
i use the car to run around in & also for my night job delivering pizza
2/3rds of the driving i do is at about 40mph
the rest is on the highway
just did the timing belt so i guess it's time to get started
i think i'll remove the grill & build a solid fiberglass grill block
i don't think a scan tool will work on a 94' because my car is a OBD1
not the later one you have.
